They’re not all the same at all
Higher rise bars, raise the height of your bars. Cockpit length should remain the same, but the relative angle between bars and front hub steepens for the downhills because they make the effective steering length of your stem longer as the bars are raised vertically, not in line with your head angle
Uphill you’ll have less weight on the front wheel because the raised bars effectively go further back when uphill
More spacers below the stem force the bars back and giving less cockpit space and less weight on the front wheel for climbing, but doesn’t affect the angle between bars and front hub
Increased stem angle (assuming same length stem) makes the effective steering length of your stem shorter. It raises the bars and brings them back. So shortened cockpit and less weight of front wheel whilst climbing
Basically, the lower the better, so long as your back, wrists and neck can stand it imo/ime
