Bought a Drayton controller / thermostat pair from Screwfix back in December. Since then my internet connection (BT Infinity) has been unreliable, dropping out on a pretty regular basis.
I put this down to the weather and a set of crappy HomePlugs. However, it’s not improved and after binning the HomePlugs the problem is still occurring. Took some advice from a local Openreach technician and wandered around the house with an AM radio trying to track down interference and voila, found this coming from the timeclock:
https://soundcloud.com/fursty_ferret/rein
The sample starts with the controller off, then switched on at the wall (the boiler power supply is isolated independently), running for about 30 seconds before I switch it off again.
With it off, the broadband works perfectly. Do you think I have any grounds for getting a refund from Screwfix?
