Quill to Ahead bodg...
[Closed] Quill to Ahead bodge
[#875277]
I got very cheap quill 1 1/8th forks for winter. They're fine, apart from the quill bit. So, I found a quill to Ahead adapter. Fine, but you can't tension the headset, which turned a "5 minute job" into 2 hours of bodge. So, I had to find a way to tension the headset...
Ta-da! (obviously the scaffolding comes off once the stem is tight...)
I expect I'll get an award for that.
Cheers, al.
Posted : 17/09/2009 2:09 pm
I cant even work out what you have done??? Couldnt you push down to tension it?
Posted : 17/09/2009 2:14 pm
So you have a quill fork with an aheadset headset and stem?
Posted : 17/09/2009 2:17 pm
You will probably get a Darwin award.
Posted : 17/09/2009 2:18 pm
pwew on looking a 3rd time I see what you was doing... Nice.. 🙂
Posted : 17/09/2009 2:20 pm
Posted : 17/09/2009 3:03 pm
Suspension forks on a pompino? /boggle/
Posted : 17/09/2009 3:33 pm
I'm confused. Quill forks. quill to ahead adapter - ahhhhhh now I see.
Posted : 17/09/2009 3:43 pm
what was wrong with the summer forks?
Posted : 17/09/2009 3:47 pm
