Before I start….
Road wheel, virtually new, used for 250 miles, including sprints around 1000w. All good. Then all of a sudden looses tension on nds and rubs on brake at less than 500w.
Checked with tension meter, nds virtually zero on nds. Tensioned back up to spec, and found the wheel was now massively out of dish and touched the chainstay on the nds. Tension on ds is at spec and virtually untouched other than to true as part of tensioning the nds.
Confused as to why / how this could have happened. Kind of assumed that if one side loosened, re tightening it to where is was would have left me with a wheel exactly as before rather than completely out of dish.
I take it the only thing for it is to completely slack everything off and start again?
