Question about sett...
[Closed] Question about setting sag
[#642304]
Just took delivery of my new brand bike, When I am experimenting with setting the sag on the fox rear shock, I notice that it takes a while to settle into the final sag position. i.e when I sit on the bike the shock compresses most of the way immediately but then takes another 5-10 seconds to creep down the final few mm's, is this ok ? Or a shock problem ? it does seem to finally settle and not continue compressing slowly, but if I remember my old bike just dropped down the appropriate amount when I sat on the bike and stayed there straight away
Posted : 17/06/2009 10:52 pm
Have you fiddled with the damping?
Posted : 17/06/2009 10:54 pm
Nope its a Float R, so no option to fiddle with it
Posted : 17/06/2009 10:55 pm
bedding in? Proper test is riding it
Posted : 17/06/2009 11:00 pm
Shocks and rebound/compression damping can be confusing and part of me things you've read too much on bike forums/dirt mags. Take it into the local bike shop and see if they think it's ok. Buy some decent tyres whilst your in there.
Posted : 18/06/2009 12:12 am
It may be the shock just needs to bed in a bit if its brand new. Can take a while for the bushings to bed in.
Probably worth riding it a few times after setting the sag roughly then check the sag again once its loosened up.
Posted : 18/06/2009 8:59 am
Hopefully it may improve after its been ridden a couple of times, bearing in mind its brand new. I suppose it could be just tightness in the seals and bushings as new
Posted : 18/06/2009 9:10 am
I spoke to Mojo, apparently its fine, all to do with the low / high speed compression on the new generation shocks. Particularly on the float R with the in built propedal. I may not have noticed before on my other shocks with manual switchable propedal as I always set the sag with the shock on full open so I guess that very high anti-bob compression tune wasnt that prevelant.
Meaning when a high speed load is acting on the shock it will move quickly as you'd expect (i.e a bump) but on a slow speed load (i.e a pedalling force or a slight shifting of weight is applied it has a high rate of compression damping slowing it down, so its not bobbing under pedalling, he said that this transition between high speed forces and low speed forces has increased a lot in the 2009 shocks onward. He said that the older generation shocks didnt do this so well.
I described to him in detail on the phone (twice !) the exact thing that is happening when I sit on the bike, and he basically said "yep, thats exactly what I would want to see happening, as it means its working perfectly"
So I am one happy camper now 😀
Posted : 19/06/2009 9:33 am
