Right!!!!!!!
not wiling to be helpful here but…..
Frog combe as a descent although not a bridleway is ok on it’s own, fast as **** with a nice rooty section then a wideish trail and abrupt water crossing point, but beware there’s a couple of trees down across the trail. For locals with out a care this is an insanely fast descent, only the rooty section checks your speed then it’s time to crank it and shit bricks hoping there’s no walkers coming.
The better side of frog is left of the combe, this is accessed by heading towards hare knapp as the wide hard pack track turns to grass bare sharp right and drop by way of a harsh narrow rut(new line seems now to be up on the left)this drops you through a rooty section then hard left on off camber roots to pick up the single track with leads to the ain frog combe track(this is the trail in the first sequence on the ‘quantock sessions vid me and jambo made).
Whilst we’re on the main heathland side of the hill, look for a trail that links longstone hill with the bottom of lady’s edge, some locals call it ‘oblivion’ it’s kinda steep with lil drops on corners with a lovely loose woodland surface that i’s near impossible to brake on 😉
On the west flank the only worth while descent to call technical is off the top of weacombe hill dropping down across the top of bicknoller Quarry, though it’s just loose steep and short.. short combe is ok but i tend to head WNW off it dropping you out opposite bicknoller quarry, it’s starts off grassy for ages then suddenly turns to single track with a couple surprise turns..40mph can be reached before the singletrack but beware of sheep, they CAN’T run that quick hee hee.
From the corner of staple plantion car park facing the combe you’ll see a trail entrance dropping east down into weacombe….this can be fun, especially went you hit the 15 or so wooden steps………
*thinks!*
AH! i know………… triscombe combe with the words at the top ” last one to the ‘blue ball gets them in’…………..lol! that’s make things technical at THAT speed.
Fer the proper tech stuff, head over to triscombe and drop in north from the slades, steep rooty, steep rooty, tight twisty and mostly steep and rooty……if you can find it on the far eastern side north of the viewpoint, Brendan fairclough track hides….enjoy….my soiled undies may still be seen hanging in the trees!
