Bear – 13th a bit late for us: Le Tour goes past our mate’s place on the 15th and we’ll already be there! Woohoo!
Another time then. (and Im doing the course with the aim of learning stuff. As for pissing around with my home CH system I consider it more of an experimental lab 😉 )
Stu’s been a top bloke and emailed me a circuit diag based around a pair of relays which fills in the hole in my understanding, and is bang on. Im very grateful.
The reason for the switching is that I have a solar thermal system that, like a nuclear reactor, cant be turned off so I need to be able to rig an automatic heat dump for when we go on holiday.
(usually losses and uses are more than sufficient to prevent an overheat, but sustained collection with no emission may be too much for the losses in the system to dissipate)
So I want to link my solar thermal controller (which turns on the solar thermal pump that brings heat from the collector to the thermal store) to ALSO turn on my Underfloor heating. Obviously only when I want it to, by a switch. My 1,500 sq ft stone floor then becomes my heat dump.
This means I have two controllers sending live to the one UFH pump, independently of each other (although obviously extremely unlikely that they do it together). The UFH controller is a timer/thermostatic jobbie with its own switch relay. The solar thermal pump is actuated by the hysteresis between the solar collector and the thermal store.
So with the relay set up, although I have to caution that there are more than one point of isolation, I can use the two relays to switch a spur to the UFH pump.
i.e. when the UFH controller say “yes”, then it’s on and not f***** with the solar controller, and when the Solar Thermal controller say “Si” it’s on too. And indeed both can be on at the same time with no problems.
