QR forks - secure?
[Closed] QR forks - secure?
[#2799641]
I have some Z150Sl's and they're QR. Plenty of wheels to choose from but I'm not very confident QR is safe enough on such a long fork. How can I make it better? Pro II hub if it matters.
Posted : 29/05/2011 9:10 am
the length of fork has little bearing on the safety of a QR system.
The following are more important:
1) Thread of QR nut should be "stiff", not sloppy
2) Cam of QR lever should not be worn
3) Drop outs on fork should be forward facing
4) Drop outs on fork should have lawyer tabs
5) Larger rotor sizes put the caliper pad higher up the fork leg reducing the angle of the force which acts on the axle path towards ejecting it from the drop out.
Posted : 29/05/2011 9:16 am
Stoner has it almost right he just forgot:
Use a Shimano QR
Posted : 29/05/2011 9:20 am
Stoner, so in plain English - a large rotor, Shimano QR and Marzocchi fork are fine. Correct? Or is a allen key axle better?
Posted : 29/05/2011 9:22 am
I've never had any issues with QRs on long forks, If you'd feel more confident using a hex head skewer, use that
Most people have no real need for a QR anyway
Posted : 29/05/2011 9:26 am
correct.
I dont see an allen bolt axle adding much additional security over a good quality QR that is regularly inspected.
Posted : 29/05/2011 9:29 am
Thanks lads.
Posted : 29/05/2011 9:42 am
6) Remember to close the QR.
Posted : 29/05/2011 10:15 am
as above, a well maintained Shimano QR will be solid
Posted : 29/05/2011 10:38 am
yep - go for shimano QR - my hope one keeps coming undone 🙁
Or you can get some hubs that take a 9mm axle for extra stiffness, although if QR that won't be a shimano one.
Posted : 29/05/2011 10:42 am
Out of curiosity, has anybody found any better than Shimano? I tried Hope - poor with my forks (couldn't close them properly), Halo - snapped the rod, unbranded - opened themselves without being ridden. There are Chromags at CRC and they look nice. Would there be a reason for buying them other than being a niche-whore?
@druidh, a valid pount 🙂
Posted : 29/05/2011 10:43 am
i recall that one brand of allen key skewers advises strongly against racing. IIRC it was to do with it not be as reliable.
Posted : 29/05/2011 10:44 am
@MrK mkII, what about mincing? 😉
Posted : 29/05/2011 10:50 am
haha, i believe the warranty is unaffected 🙂
Posted : 29/05/2011 11:02 am
I thought that the DT Swiss 10mm ratchet skewers were supposed to be more secure than standard QR,but pricey.Hope hubs can easily be switched to 10mm too.Superstar do a budget QR version.
Posted : 29/05/2011 11:04 am
Shimano skewers are great. Salsa are the only ones I know of that come close.
Posted : 29/05/2011 11:23 am
DT RWS are 9mm btw and fit in standard QR dropouts, have one on the Stumpy, very good it is too.
Posted : 29/05/2011 11:25 am
I'm struggling to recall anybody ever actually saying that 'brand blah qr skewers are more secure than Shimano'.
I can't really seen any advantage in trying anything else.
 flow
QR has obviously been around for longer than you have been riding, you will be fine.
Posted : 29/05/2011 11:51 am
@flow, not quite true, but 150mm of travel, 456SS and QR seem(ed) a bit of a mismatch.
Posted : 29/05/2011 11:54 am
 mboy
If you're worried, get the 9mm axle adapters for the pro2 hub, and an axle from either DT or Superstar. This setup is definitely more secure than a conventional QR, and fits in normal QR dropouts.
Or just use a Shimano QR and make sure its in good condition and done up tightly.
Posted : 29/05/2011 11:59 am
And closed the right way. A mate of mine Isnt that mechanically minded and when ever I see him he's done the QR up real tight with the QR full open
Posted : 29/05/2011 12:05 pm
@mboy, I'm not worried, more like uncertain. I'll stay with the Shimano QR's then (if I can find the front one) for now.
Posted : 29/05/2011 12:40 pm
I have 9mm DT Swiss RWS on my 5 and XT QR on the hartail. The 9mm bolt through is stiffer, but I'd not say more secure than a properly setup QR.
Posted : 29/05/2011 12:56 pm
The main thing with QRs is checking them every ride IMO.
Only once have I seen a front QR fail (Rider error, poor maintenance) and I was right behind the guy at 20mph++ when his wheel came out.
This was the days of toeclips and the first thing to hit the floor was his face. It wasn't pretty. AFAIK he never rode a bike again after having his jaw and lower face reconstructed.
Posted : 29/05/2011 2:35 pm
 flow
That would not be good!
Posted : 29/05/2011 2:40 pm
