I used to have a thompson freeview/ top up TV one but had to switch to a Humax freesat when I moved house as the the terrestrial signal wasn't good enough for freeview.
The Thompson had the better programme guide – 2 weeks rather than one, more intuitive to use too. Its only downside was that it was unreliable beyond all imagining. Just about any action would cause it to freeze, lock up. It would fail to delete, fail to record, create fantom recordings that were 23hrs long. Utter utter garbage.
Yours for absolutely no money of you want it, or I can throw a rock at you, not sure which would be kindest.
The Humax interface is a bit more of a fiddle, easy to forget how to do certain things almost as soon as you've worked out how to do them. But….. utterly rock solid reliability. Flawless
