I’m a bit disappointed with the OS Getamap thing – if you try and plot multiple routes with lots of waypoints on the same map it takes forever to load and then, after a while, you can’t add anymore – you get an error and can’t save until you remove some waypoints – annoying when you’ve plotted your coast to coast as far as Osmotherly. Can’t find anywhere in the FAQs of Help that’s there’s a limit, but there bloody is.
And, even zooming in and out, viewing on screen just isn’t the same as a fully unfolded OS sheet or, even better, two or more fully unfolded sheets spread over the floor.
I bought 4 x 1:25000 on cg’s tip (thanks again for the PSA), I’ve got all the maps I need for the coast to coast now (or I will have when they arrive), so bugger getamap, it’s pencil and paper route plotting for me..
