I was interested in trying out 650b, but put off by the cost.
I knew my frame and forks would accommodate them, and fancied having a lighter set of tubeless XC wheels that I could use for normal riding, and then keep the burlier/wider/heavier 26″ ones set up with heavier tyres and DH tubes.
So after a bit of googling and searching I found these:
Mavic Crossroc 650b Wheelset on Rose Bikes
£139 all in including 2.2″ tyres, tubes, & tubeless kit. Front wheel is 15mm axle, and rear is 12×135 or QR. Delivery was about £7.
Rims are 24mm wide (19.5mm internal measured with my verniers). So not fashionably wide, but not too skinny either.
Mine arrived yesterday, and they seem up to the normal quality that I’d expect from Mavic. I’ve just fitted the tubeless rim-strip to the back wheel, and the tyre went on easily and up with a track pump no sweat. Not added sealant yet, but it seems to be holding air anyway 🙂
Yet to ride them, but will set up the front wheel tonight, add sealant to them both and hopefully give them a shakedown at the weekend.
