Been running X0 1×11 for quite a while now with no problems whatsoever until recently when I can’t get it to select the 42t cog and stay in. Been adjusting the cable tension as I go and sometimes I think it’s work but then it plays up again so today I set about it properly.
Thinking it can only be the H/L adjustment or cable tension, I disconnected the cable and gently pushed the mech over and sure enough all gears selected cleanly, so not the H/L adjustment. Reattached the cable and adjusted the tension so it changed into the 10t smoothly. This left it changing 10 cogs cleanly but again not the 42t, it would go onto the cog and then immediately come back off, then off, then on…… If I adjust the cable tension to the max so it wouldn’t even change in the 10t, it still wouldn’t go onto the 42t and stay on.
At this point I was confused, any advice on this one?
