So after building up a Mega TR with mostly components from my other bike, including a set of Pro 2 Evo/Flow EX that I bougth about 1,5 years ago, I experience a clonking sound when applying power. I first assumed it was the chainstay/seatstay bushings as that’s a common fault with these frames, but after replacing them the problem persists. I’ve narrowed it down to the rear wheel as I can recreate the clonking by wiggling the rear wheel side to side (I can’t recreate it by doing the same with the rear triangle itself which should confirm that the bushings are no longer the problem, if they ever were). The hub sits tight in the frame so I can only assume the play is in the hub itself.
So, is it definitely the bearings, or could it be something else? I’ve removed the freehub body, cleaned and regreased everything and reassembled it with Hope’s video playing just to make sure all the parts are in the right place. I didn’t remove the axle or bearings from the hub shell as I don’t have the tools but they felt smooth and play-free to my hands, but maybe that’s no guarantee they’re actually fine?
