Power link/lock for...
[Closed] Power link/lock for a 10 spd road chain.
[#3768224]
I know this has been done several time before, but let's assume for a moment I'm being a lazy-ar$e this morning 🙂
What's the best Power Link (ideally) or Lock (would be fine) for a 10 spd Shimano road chain?
Ta.
Posted : 13/03/2012 10:30 am
[url= http://singletrackworld.com/forum/topic/what-10-speed-powerlock-for-ultegra-road-chain ]shall I bring your slippers too sir ?[/url] 😆
Posted : 13/03/2012 10:32 am
KMC Missing Link for my money.
iainc - You're getting the idea! 🙂
Posted : 13/03/2012 10:33 am
A 9-speed Powerlink will be fine.
Just get a 10sp KMC missing link
Posted : 13/03/2012 10:38 am
I guess this is borderline trolling, so apologies in advance, but I'm forced to ask why?
Last I checked, Shimano joining pins were cheaper than powerlinks/locks and if you're prepared to use a powerlock (i.e. not be able to open the link again) then why not use a pin?
You'd be carrying a chain tool anyway and joining pins take seconds to install?
I guess I don't see the sense in going out of your way to find another manufacturer's alternative to a solution developed precisely for your chain. Is there some drawback to using joining pins that I'm not aware of?
Posted : 13/03/2012 11:18 am
PowerLINKs can be reused and work fine. The chain can be removed and refitted without a tool. What's not to like?
Posted : 13/03/2012 11:21 am
I got the impression Bristolbiker wasn't too fussed about removing the chain as he said he was be happy to use a powerLOCK.
Frankly, I just don't like powerlinks once SRAM saw fit to start charging so much for them 😕
Posted : 13/03/2012 11:25 am
+1 KMC missing links ... got them on shimano, SRAM and KMC chains 😀
Posted : 13/03/2012 11:57 am
Decathlon do links, 2 for £4
Posted : 13/03/2012 1:09 pm
I would like a Link to make taking the chain on and off for cleaining easier.... and it seems like there is a solution for that.
I would have put up with a lock, rather than using the joining pins 'routinely', as it seems like a better solution if I was going to have to split the chain as (IIRC) the pins plastically deform the plates, hence it's not a good idea to break/rejoin the chain at the same location.
If I'm 'out in the field' I tend to carry spare power links, rather than pins as it's less hastle to push out the duff links with a chain tool and then put the chain back together in a matter of seconds with a spare power link.
Posted : 13/03/2012 1:41 pm
KMC missing link - I have reused SRAM power link 10sp with a link remover a few times without any issues 🙂
Posted : 13/03/2012 2:42 pm
Anyways - some Missing Links ordered, so thanks all.
Posted : 13/03/2012 2:45 pm
