How many turns does it take to turn the stopcock from fully on to what appears to be ‘off’? If ours has not been turned for a while, it needs an adjustable spanner to get it to turn off properly. I assume the hard water is furring it up somehow.
For diagnostic purposes, an almost closed valve results in the same pressure, at low flow. Only in high flow does the reduction become visible. So unwind the valve fully, and see what flow you get from a bath tap. Then close it as far as possible, and see what the difference is. If there’s no difference in flow, the valve is on a different pipe!
