Please show me your...
[Closed] Please show me your single rings... (yet another single ring thread)
[#3104552]
I'm looking at a single ring setup for a new trail bike build. Just wondering what cranks and rings people use for theirs and what needed to be done (e.g. shorter bolts, sorting out chainline.)
Am looking for quite a clean look so the Middleburn R8 x-type cranks are tempting, but XT seems a more sensible choice. Photos of setups would be cool.
Posted : 01/09/2011 3:14 pm
I'm just using SLX cranks with a normal 32T shimano ring. Looks a bit horrible, but works.
Posted : 01/09/2011 3:21 pm
Old photo but ......
Posted : 01/09/2011 3:22 pm
Probably not particularly helpful for what you want but you did put out a request for a single ring show 😉
Posted : 01/09/2011 3:25 pm
Thanks letmetalktomark, that's the sort of thing I'm after. Looks like it's on a Soul too which would be exactly what I'm after! Is that a renthal ring? Not tempted by the Uno chainrings from middleburn and ditching the spider?
Slugwash, thanks but not quite the look I'm after!
Northwind, got an SLX double that I could try but don't think it would look that good. Price is quite tempting though.
Posted : 01/09/2011 3:36 pm
Posted : 01/09/2011 3:38 pm
Not got a photo as I can't get to FlickR at work, there's one in the first post [url= http://www.singletrackworld.com/forum/topic/so-got-my-top-fuel-under-20lbs ]here[/url].
I'm using a custom 36t ti chainring from Mathias Helore on M985 XTR Race cranks, bolts from eBay, bodged Superstar chainguide (which has been awesome). No problems with chainline either. Did bend the ring quite badly when I broke a chainring bolt, but being ti a just hit it with a hammer to straighten it - it's not perfect, but it's good enough, still never dropped the chain.
Thanks njee20. Is that an XTR double? I'm quite tempted to pick up the new XT double and run that in a similar way (put off by XTR due to dodgy BCDs.) Don't want a bash guard on it so reckon it should be ok. Is that just running where the big ring would have been or have you done anything else to it?
Posted : 01/09/2011 3:45 pm
Yes it is the double, hence having to use a custom chainring for the 88mm BCD, although actually it was really cheap! Not done anything else - it's just where the outer ring was.
If the XT just has normal 64/104 BCD then yes you can just run the ring in the outer position and it'll be fine.
Posted : 01/09/2011 3:53 pm
@ Mr Blobby - Yes its a Renthal.
Set up didn't last long as to get the MRP guide into its correct place meant it fouled the back of the crank.
Not long after the photo was taken I went with a bash guard and a N gear guide.
No issues with that set up at all.
Then went 2 x 9 with a Duo as was fed up spinning out on the flat bits!
Also ran a UNO rind with a N Gear stop on another bike but found I lost the chain couple of times. Would have been fine with the Renthal ring as it has taller teeth.
Old pic:
Posted : 01/09/2011 4:05 pm
I do like that Uno. Though I've just gone and ordered the new XT double. Has the 64/104 BCD so should be able to run a renthal single ring where the big ring is. Hopefully should give quite a nice clean look, and can always go back to a double if my legs aren't up to the job!
Posted : 01/09/2011 4:18 pm
 oink
old photo as now using an mrp mini g sl chain device
but race face sixc cranks and e13 guide ring
Posted : 01/09/2011 4:42 pm
Sixc, nice but very pricey.
Posted : 01/09/2011 5:48 pm
Posted : 01/09/2011 5:50 pm
Posted : 01/09/2011 6:03 pm
[url= http://farm7.static.flickr.com/6142/5964437955_2c0812963e_z.jp g" target="_blank">http://farm7.static.flickr.com/6142/5964437955_2c0812963e_z.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/59190559@N05/5964437955/ ]020[/url] by [url= http://www.flickr.com/people/59190559@N05/ ]bluerichiepig[/url], on Flickr
Posted : 01/09/2011 7:34 pm
Posted : 01/09/2011 8:05 pm
Ooo Richie that looks like the new XT double, looks good. Went for the silver myself.
Ricks, like SLX with the gamut, looks a lot better than the shimano slx bash.
Posted : 01/09/2011 8:29 pm
Posted : 01/09/2011 8:59 pm
Cheap way, Deore HT2 cranks's & middle ring with Superstar chain device. Chain device works very well, & they do a Pauls Components type one now that looks better.
[url= http://farm3.static.flickr.com/2718/5837624536_dbd4a39029_z.jp g" target="_blank">http://farm3.static.flickr.com/2718/5837624536_dbd4a39029_z.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/takisawa2/5837624536/ ]IMAG0525[/url] by [url= http://www.flickr.com/people/takisawa2/ ]pten2106[/url], on Flickr
Posted : 01/09/2011 9:07 pm
[img] ?psid=1[/img]
2 sets of rotor Q rings in single ring set up on middleburn cranks..lovely
Posted : 01/09/2011 10:02 pm
The sweed, what you got going on there?
Hmm hadn't considered rotor q rings. Just like the biopace ones on my old road bike 🙂
Posted : 01/09/2011 10:19 pm
All three rings from [url= http://homebrewedcomponents.com/ ]Home Brewed Components[/url]
XTR M960 jeff jones SS mod:
[url= http://farm3.static.flickr.com/2739/5792091218_1fff28e435_z.jp g" target="_blank">http://farm3.static.flickr.com/2739/5792091218_1fff28e435_z.jp g"/> [/img][/url]
LX cranks with Roox Chaindog:
[url= http://farm7.static.flickr.com/6070/6095110464_e3e90507f1_z.jp g" target="_blank">http://farm7.static.flickr.com/6070/6095110464_e3e90507f1_z.jp g"/> [/img][/url]
Middleburn RS7s with Pauls Chain Keeper:
[url= http://farm7.static.flickr.com/6087/6102878009_fa561f45d8_z.jp g" target="_blank">http://farm7.static.flickr.com/6087/6102878009_fa561f45d8_z.jp g"/> [/img][/url]
Posted : 01/09/2011 10:29 pm
I had a good deal on the new 2012 xt chainset 🙂
Posted : 01/09/2011 10:40 pm
A few of mine and a Ribble I built for my 73 year old dad ( saddle lowered before delivery 🙂 )
Posted : 01/09/2011 10:41 pm
Ajantom, did you jones those M960's yourself? Can you send it off somewhere to get it done? Got an old M960 in the shed and would be tempted.
Posted : 01/09/2011 10:45 pm
Did em my self - here's a better shot:
[url= http://farm5.static.flickr.com/4011/4322164083_b3f67f6c75_z.jp g" target="_blank">http://farm5.static.flickr.com/4011/4322164083_b3f67f6c75_z.jp g"/> [/img][/url]
and a shot of the steps involved:
[url= http://farm3.static.flickr.com/2503/4094165208_41ddf71b4a_z.jp g" target="_blank">http://farm3.static.flickr.com/2503/4094165208_41ddf71b4a_z.jp g"/> ?zz=1[/img][/url]
Hacksaw of the ends, file down to make em round (helps if you have access to a grinding wheel!), then a s**t load of polishing with wet & dry. definitely a winter evening job!
I could've spent a lot longer polishing with finer grades of wet & dry for a shinier finish, but life's too short 😆
Posted : 01/09/2011 10:48 pm
 P20
Goldtec. Cheap, well made. I had this on my singlespeed and i'm thinking of them for a 1x10 set up. Probably not the lightest though 😆
[url= http://farm5.static.flickr.com/4036/5135804542_99c2f5cd78_b.jp g" target="_blank">http://farm5.static.flickr.com/4036/5135804542_99c2f5cd78_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/66452821@N00/5135804542/ ]DSCF8164[/url] by [url= http://www.flickr.com/people/66452821@N00/ ]ritcheyp20[/url], on Flickr
Posted : 01/09/2011 10:57 pm
Identiti Mr Hyde. 34T Blackspire chainring, RaceFace Ride cranks, BB and bashguard, Superstar Plasma chainguide (yes I know - upper guide has been knocked out of alignment in the close-up). Only work needed was to remove original double rings from the Ride chainset & replace with Blackspire ring. May well soon remove bash and fit replacement 'non-bash' chain cage for the Plasma.
DMR Trailstar Mk2. 40T Gusset Tribal ring, Octane One cranks and ISIS BB, DMR Chain Cage & Chain Reactor. No mods necessary
slainte 😀 rob
Posted : 01/09/2011 11:06 pm
Posted : 01/09/2011 11:40 pm
[img]http:// http://m.flickr.com/lightbox?id=6104081327 [/img]
Posted : 01/09/2011 11:57 pm
Liking those Jones conversions a lot. What rings are you chaps running and how easy are they to get hold of? I know blackspire do 32t and 34t in the 104 BCD, but the are made for running as a triple and don't look that nice.
On and on, liking that Curtis.
Posted : 02/09/2011 7:45 am
[img] ?psid=1[/img]
another set of home polished and trimmed cranks with a surly 32 stainless ring
Posted : 02/09/2011 7:47 am
Yes, and the Blackspire ones are made of cheese - lost a tooth on the second ride when I had one 😯 (BTW the XTR M960 are a 102bcd)
Honestly the guy I mentioned - [url= http://homebrewedcomponents.com/ ]Home Brewed Components[/url] - is by far the best option.
Custom CNC ring to fit your XTR cranks for $35 + about $10 for postage. 31-36 teeth, and anodised any colour you want 8) He also does Ti rings, but they're a [i]little bit[/i] more expensive!
Posted : 02/09/2011 8:20 am
Doh, still a bit early morning for me!
Pretty good price there. Being custom do they take ages to turn up?
Tazzy, loving the frame.
Posted : 02/09/2011 8:38 am
5-bolt is the way to go 😉
A Surly stainless steel ring can be straightened when damaged and the teeth last for ages.
I quite like the look of these in Ti though:
http://www.homebrewedcomponents.com/store.php/categories/pictures
Yes get shorter bolts, I like steel ones, and get the right length BB or use some of these to sort your chainline out: http://www.velosolo.co.uk/bbspacers.html
Posted : 02/09/2011 8:43 am
5 bolt, old school.
110 dollars for a titanium ring!!! I want 🙂
Posted : 02/09/2011 8:49 am
About 2-3 weeks. Though the first one was ages and the 3rd one really quick. I think he saves up orders to then do a run of rings in one go.
Posted : 02/09/2011 9:09 am
I got my ti chainring from [url= http://hellore.se/experimentalprototype/ ]here[/url], €40, although I think that's because he had another order for one so all the tooling was set up. He does 102 BCD rings though, and the ti ones are far cheaper than HBC. Mine's lasting perfectly.
Posted : 02/09/2011 9:19 am
Liking their ceramic coated 960's. Nice.
Posted : 02/09/2011 9:52 am
Agreed, their chain guides are really nice too, but are €90+, and look a bit 'home made' (as they are!) in the flesh!
Posted : 02/09/2011 9:53 am
Posted : 02/09/2011 10:16 am
Gamut P20, 32 tooth RaceFace chainring, 9spd cassette
Posted : 02/09/2011 2:28 pm
[img][url= http://farm7.static.flickr.com/6198/6104081327_2f51d071e0.jp g" target="_blank">http://farm7.static.flickr.com/6198/6104081327_2f51d071e0.jp g"/> [/img][/url][/img]
Posted : 02/09/2011 5:59 pm
