Play in SRAM cranks...
[Closed] Play in SRAM crankset / GXP BB. New BB time?
[#3570743]
I've got a SRAM rival crankset on the CX bike with the standard SRAM GXP BB, and noticed that there is a bit of lateral movement in the crank arms. Not terrible, but definitely there. I've tightened up the non-driveside bolt, but there is a still a bit of play.
I'm assuming that the GXP BB has had its day. It is only 4 months old, but I wouldn't be surprised, as it's had a wet and muddy winter of CX racing. Time for a new one, or anything else to be done first?
What's the opinion on new BBs anyway? Spend the extra for Hope and a GXP convertor, or treat the GXP ones as disposable and replace every winter?
Assuming the BB bearings are on their way out (bike funds are presently a bit tight), much harm in running it for another month? Presumably I am only wearing out an already worm out GXP BB?
Posted : 16/01/2012 3:50 pm
IMO, throw the GXP setup in the bin and move to Shimano.
Posted : 16/01/2012 3:56 pm
Assuming that isn't an option (i.e I don't have funds to swap out a perfectly good set of SRAM crankarms for some new Shimano ones), would you therefore suggest that a Hope or other BB is going to be better than another SRAM GXP?
Posted : 16/01/2012 3:59 pm
i dunno sorry, i used 3 SRAM GXP BB's in the past.. all went fairly badly.... so i moved away.
Posted : 16/01/2012 4:00 pm
 XXX
not ideal but normal, its just bedding in. All it needs is a thin spacer between the frame an bb cup. I think crc sell them....
Posted : 16/01/2012 4:01 pm
Fair point. I've already got a slim one in there from new to take up the slack (although I'm told I shouldn't need one on a CX frame), but I'll maybe bung another slim one in and see if it will take up the slack and keep the BB going a while longer.
Posted : 16/01/2012 4:11 pm
 XXX
I think the tolerance on frame bb width they work on is much tighter than most frames, hence the bad reputation...
Posted : 16/01/2012 4:20 pm
+1
Posted : 16/01/2012 4:26 pm
