Kael pointed me to this thread…. 🙂
Is it the standard Hub on a spesh Pitch?
If so get hold of Peter Posdy on here. He will know!
Err. Ummm. Not really! 🙂
I do have a Pitch, but the standard wheels went looooong ago and I’ve got Lyriks and a Pro 2 on it now. I do however recall what the Spesh hub looked like.
The two ‘cones’ you can see sticking out from the hub are the 20mm adaptors, like on a Hope Pro 2. Hope adaptors are secured with a small clip and it’s very easy to pop them off, then knock out the cartridge bearings underneath them to replace
The Spesh hub seems to have the adaptors fitted in some way they it’s not obvious how to get them off. I’m guesing there’s cartridge bearings underneath them like a Pro 2, which are the likely the source of play. Don’t ask me how it comes apart! Me? I’d go to my local Spesh dealer and ask them to tell me!
One last thing, the ‘adaptors/cones’ are always a bit loose. They should be. They tighten down when you lock the Maxle, so don’t worry about that
Let us know if you find how it comes apart, someone MUST know! 🙂
