exactly the same on mine (see thread from few weeks ago in my history)
mine only is noticeable when lifting the front end up as per lowey – the forks are fine and dandy in operation, no knocking/klunking etc when riding
ive just had the lowers off on mine after 2.5 monhs of hard use, and the seals are still white and the oil is clear and still the right amount! impressed!
also as someone said above, if you put the rebound to fully slowest the play disappears completely (even lifting by stem), rebound fully fast it appears at its worse….
i thought mine were buggered as i was getting terrible performance (which in hindsight was the headset bearings 😳 )
so yeah pretty normal from what i can tell and not noticeable riding for me
