Resurrecting forks for a build and when they were last used (apart from generally being ready for a lowers service and oil etc) they had developed an air leak such that a normally sagged fork, wound down to 110 to earn the descent with would not actually extend when wound back out – unless you shook it and then it’d be obviously under-pressurised. No rough feeling and no stanchion damage.
Based on the SRAM tech stuff, I’m thinking this is the o-rings on the air piston – although i’ve never investigated/tried the heavier oil to see if it improves briefly trick.
Any other ideas? Or does my diagnosis sound about right?
