Peugeot 307 hdi
[Closed] Peugeot 307 hdi
[#1452062]
Just bought one and within 48hrs the engine management light is on displaying depollution system fault. Is this a common problem? Any suggestions as to which sensor might be causing it?
Posted : 27/03/2010 11:29 am
Take it back.
I assume you have one with a 'DPF'? The system monitors the pressure difference across the particle filter and will put the light on if the filter becomes blocked. You need a code read before anything else.
There is no cheap fix I'm afraid.
Hth
Marko
Posted : 27/03/2010 11:46 am
Sometimes a blast down the motorway, for a car that has been used mostly in town can sort the problem.
http://www.honestjohn.co.uk/forum/post/index.htm?t=81969
Posted : 27/03/2010 11:54 am
All ready been on tithe garage. They are having it back as soon as I can get it down there. So far I have read that it could be a sensor on the turbo or egr valves seem to be favorite but when that happens the engine goes in to safe mode and won't rev pass 2000rpm but I have still got full revs?
