park inner tube pat...
[Closed] park inner tube patches.
[#2908686]
Is it just me or are they rubbish? Or are they just meant to be a temporary fix, just enough to get you home sort of thing.
Posted : 02/07/2011 7:59 pm
They are great. Fast permanent fix for both road and MTB pressures, also make great frame cable rub protectors. What's not to like?
Posted : 02/07/2011 8:10 pm
Poor in my experience, temporary repair that doesn't like higher pressures. Now slime patches or superstar ones stick like wotsit to a blanket.
Posted : 02/07/2011 8:14 pm
Never had to use one myself, but came across a broken down roadie with a flat months ago. Offered to give him a lift home, he was determined to fix his flat. Lent him my track pump to get things going, both his spare inner tubes split when pumped.
Remembered these in the car and he found the hole and patched it, got the pressure up to about 100 to get the last 50 miles home.
Presume he made it.
Posted : 02/07/2011 8:22 pm
used them many a time. Fantastic little ride-savers.
Posted : 02/07/2011 10:01 pm
i think they are made of the wrong stuff with not stretch when inflating the tube
Posted : 02/07/2011 10:09 pm
Very good, used them loads.
Posted : 02/07/2011 10:12 pm
Use them quite a bit and have always been great. Now the BBBs sticky things, they are crap!
Posted : 02/07/2011 10:15 pm
What's the key to getting them to stay put then? I give the tube a rub with the sandpaper and bit of a wipe clean and press them on but I now have several tubes with slow punctures.
Posted : 02/07/2011 10:22 pm
 Milt
they work for me, but don't stretch with the tube too well, so you end up with exposed glue around the edge of the patch. Not sure it's enough to stick to the tyre, but may be an issue.
Posted : 02/07/2011 10:48 pm
I never got on with them on tubes but they have been ace on my camelback bladder after an over the bars put a hole in it.
Posted : 02/07/2011 10:52 pm
I have mixed experiences with them. I think you get some that are poor and/or the brand of tube makes them either work or not. generally they are ok but I always replace them with a permanent patch
Posted : 02/07/2011 10:58 pm
not as good as a normal patch - I've had 2 or 3 fail after a few months.
Posted : 02/07/2011 11:15 pm
 P20
I like them. They just seem to work. I've used on the inside of tubeless tyres to seal splits too
Posted : 03/07/2011 1:51 am
They are a great trailside fix, though I have found that overtime they begin to leak, this I think is due to their lack of stretchiness. When I get a number of innertubes in the shed needing patched I replace all the park patches with traditional rubber patches - this solves the problem of the eventual Park patch leak.
Posted : 03/07/2011 2:07 am
It's the only product from Park I think is crap, they make great frame protectors against cabe rub though.
Slime green patches or those little back suckers from Halfrauds work best for me on the bikes I've not gone tubless with
Posted : 03/07/2011 7:01 am
