Years ago there was a fuss about disc brakes making QR wheels eject themselves from forks (Google James Annan), so I ran a bunch of tests. Basically, the cam action on many QRs is rubbish, lots of them don’t have any past-centre action. The ones with the plastic insert are rubbish too, that deforms.
Best ones I tested were bog standard Shimano.
Another overlooked factor with QRs is that the nut has to grip tightly onto the dropout – alu nuts don’t grip so well, steel nuts with good serrations are much better. Ditto with the hub – a hub with good serrated faces will be more secure.
think the shimano advice is good (and from a good source), I run two sets of 700c disc wheels on my CX (road/gravel/single track not racing)one set shimano the other SRAM if you google you’ll find the brand to most specifically avoid (neither of the above).
I find security skewers hard to get right – even using torque wrench but maybe that is just me 🙁
having read all the stuff on brake forces ejecting disc wheels been a bit concerned because I have had a time when my disc has made a funny tinkling noise and I now tighten my QR’s much tighter than I would like and check them again before long fast down hill sections – but I’m sort of OK with it having said that I’m a lightweight and not an aggressive rider – the fact that nearly all disc road bikes in the last few months are thru axle says the engineers can’t beat the lawyers – and my next bike will be thru axle
