- This topic has 69 replies, 33 voices, and was last updated 6 years ago by mindmap3.
Overbiked ? Underbiked ?
adamthekiwiFree Member
@jonas – test ride as many as you can in your price range, ideally on similar terrain to what you want to ride. Buy the one that makes you grin the most.
I rode a 100mm hardtail for years. Loved it. Took it to the Alps. Loved it. Got a too-good-to-pass-up deal on a 120mm full sus. Was a bit “meh” – sold it when I realised I was always choosing to take the hardtail out. Persuaded to demo a Banshee Spitfire (160 front, 140 rear), way more travel than I thought I’d ever need. Loved it. Demo’d loads of other bikes to try to persuade myself not to spend all that cash. Came back to the Spitfire – now I ride it everywhere and never fail to return from a ride grinning.
maxtorqueFull Membergwurk – Member
Running your fork “deliberately soft”. ie. with too much sag ie. For “comfort” while pootilng around is going to equate to blowing through too much travel the first time you hit a transition or infact make any manouver where you are pushing through your bars or riding your bike properly.
er so what?
Did i say i’d be running in “comfort” settings when smashing it down a double black downhill run? I’m talking about being able to soften off your fork for when you want comfort over impact absorbance. In the UK, despite what you see on the gnarr-fest that is you-tube, a lot of people, me included, ride a lot of miles on stuff best described as “pretty tame”.
For example the other day i rode 25 miles along the Ridgeway for example, and at no point did i huck off anything, or need to push through the bars, what with it been a basically flat gravel and clay track! But, it’s cut up to heck by horses and when that dries, it dries into a horrible jarring washboard type of surface, and by running lots of sag, i could just roll straight through it all whilst sat down an pedaling (which is what you’ll be doing if you ride somewhere similar) On a short travel bike that sort of surface can get pretty wearing pretty quickly (i should know, i’ve raced events over the same routes on my XC race HT, and it beats the crappola out of you!)
Again, no, don’t run your fork so it’s sat in the bump stops, that NOT i’m saying, i’m saying that a long travel fork can be set up to ride in different ways by changing the base pressure and volume spacers to suit different terrains. A short travel fork, well, not so much, because as you point out, if you soften that off too much you will be into the bump stops more often
Surely that’s not too hard to understand is it?
(or are you too busy just being deliberately obstreperous?? 😆 )
doomanicFull MemberI went from a 120mm 26″ Spesh Camber to a 160mm Nukeproof Mega 275. I was riding three times a week back then and fitter than I am currently. Unsurprisingly, the Spesh is faster on the way up and the Nuke faster on the way down. The Nuke fits me better though and I like riding it more, so the Spesh has been handed down to my son. The gap on the way up is closing as I get my fitness up to where it was when I had the Spesh.
Is 160mm more than I need? Probably, but who cares? I like it.gwurkFree MemberSoftening a long travel bike’s springrates for 25 miles of bridleway riding?
Really?
erm… ok. :/Deliberately obstreperous?
No. far from it. You asked me to enlightened you regarding the poor advice you give. I took the time to explain something very basic to you. You can’t grasp it. Fair enough. I tried. No skin off my nose. I’ll leave you to enjoy your badly set up bike.now back to these guys…
[video]https://www.youtube.com/watch?v=XWQMMPFtoG4[/video]
steel4realFree MemberGet a room you two !
Thing is a lot of folk have one bike. Locally to me and those I get to ride with it seems that most want that bike to do it all and it’s descending most enjoy so bikes are mostly 140 – 160mm. And as it’s generally the 150-160 bikes that have the slacker fronts that’s what most are. No one cares that the bike may weigh a pound more they just want to enjoy the downs. And most modern bikes with that kind of travel climb OK as well. ‘Overbiked’ for the canal path, yeah but who really cares ? ‘Underbiked’ for Fort Bill, yeah but do they care ? Nope, just the STW hand wringers.
ceeptFull MemberIt’s not long ago that 150mm bikes were winning world cups. If you “need” more than that, you must ride some interesting terrain.
I have just got a 130mm bike (having not ridden much for 10 years) with a lock out, which helps on climbs. When I get round to it, I will increase the oil height in the forks to make them more progressive at the bottom of the travel, but tbh, they are really soft just now, and I rarely use more than 50% of the travel on a dh as my weight is over the back wheel.
Really?so you run with the same suspension settings for sending it down a WC DH track as you would taking part in a 1000mile marathon event?
maxtorqueFull MemberSimple fact is, the longer your fork, the lower spring rate you can run before you hit the bump stops (F=MA and V = FT) for any given deflection.
weeksyFull Memberso you run with the same suspension settings for sending it down a WC DH track as you would taking part in a 1000mile marathon event
Is it bad that my answer would be yes.
I’m doing Afan in the same settings I did the SDW, the same ones I did BPW on
maxtorqueFull Membernot at all, it’s all personal choice!
for me, i’d run way higher pressures for smashing down a DH run at max chat that i would for a 25 mile pootle along a horse rutted bridleway.
And that’s really my original point, the longer your fork, the more window you have for setting up differently even if you chose not too 😉
gwurkFree MemberIt’s probably best I leave you to figure it out yourself.
so long as you enjoy the ride!
maxtorqueFull MemberNot trolling, but i’d love you to properly explain what i’m missing?
Say you want to change the velocity (v) of an object of mass (m)
As F=MA, and V = FT, a given deltaV can be achieved with either a higher force over a shorter period, or a lower force over a longer period. So, the longer travel you have on your suspension, the softer (lower spring rate) you can run. The end result in the same deltaV but as every force has an equal and opposite fore, a lower force over a longer period is more “comfortable” especially for devices such as pedal and motorbikes where the ultimate ratio of sprung to unsprung mass is characteristically poor.
TheArtistFormerlyKnownAsSTRFull MemberIs it bad that my answer would be yes.
Which one of those is a WC DH track?
gwurkFree MemberForget the first year Uni mathematics/physics
Let’s go back to your stupid 1000mile on a WC DH bike anology…
Would you really want your suspension cycling through all 200mm on the sort of bumps you find on a bridle way?
No.
Just because you payed £800 for 170mm of suspensionz doesn’t mean it’s appropriate to set it up to be using it all on every ride.
Blowing through travel too easily is not only horrible. it performs poorly, results in an unstable ride and loss of grip.maxtorqueFull Membergwurk
Forget the first year Uni mathemeatics/physicsLet’s go back to your stupid 1000mile on a WC DH bike anology
Ignoring the fact i have repeatedly said i’m not talking about letting all the air out of your fork, say just moving the sag % about 5 or 10%, ie, if you’d run 25% normally, then 35% sag brings a more comfortable secondary ride frequency without major differences in primary ride frequency (which for something of low mass like an MTB is set more via the damping components (inc. friction) for low velocity damper extensions
Why would it “cycle through it’s travel” when there is no inputs from the road surface to force it to do so!
gwurkFree MemberNo matter how retarded it is. If you genuinely enjoy riding bridleways more while being sagged 35% into a 170mm fork keep doing it.
it’s your money.
RickDraperFree MemberBy the logic in this post everyone should be rolling around on DH bikes as thats all anyone needs. Sag it your if you are on a canal towpath, reduce the sag if you are riding gnar. SICK.
maxtorqueFull MemberSorry!
I thought i had missed some critical fact, as i obviously haven’t got a clue what i’m talking about, but it turns out that no, i hadn’t, or at least if i have, gwurk is for some reason unable to articulate the issue!(btw, i spent 3 years as a WRC suspension engineer, during which time we won the championship so i can’t be that bad at suspension eh….. 😉
gwurkFree MemberI’m guesing the WRC driver didn’t weigh 6x more than their car?
or constantly move from the front to rear and side to side of the car for the duration it’s journey to…Tom_W1987Free MemberI always think your better off using say 90% of your 130mm travel most of the time than lugging round 160mm of travel that you only fully utilise 10% of the time.
No you aren’t, that means you have very little left in reserve for either sending it large or making a mistake.
I’d rather run a 160mm stiffer, than drop down a 130mm bike and run it softer. The former is going to be more playful and safer to ride.
weeksyFull MemberWhich one of those is a WC DH track?
None, but if i took my bike to the Alps i wouldn’t change the settings either.
oikeithFull MemberI dont get the arguemnt between Gwurk and Max, fork settings are personal choice. I have a 160mm Lyrik which I run just over 30% SAG everywhere.
Overbiked or undrbiked, did anyone ever die from being overbiked?
mindmap3Free MemberI wouldn’t dismiss shorter travel bikes – my Scout is a little hooligan of bike despite only having 125mm of rear wheel travel and being designed to run 33% of sag.
I’ve had a 160mm travel bike before and it did feel like hard work on the tamer stuff (on the right stuff it was brill though). I ended up going the other way and riding hardtials but have ended up on the Scout and am so far really happy with it.
I tend to run my suspension at 30% sag (my Yari’s don’t have any tokens in them). Works for me.
Tom_W1987Free MemberI tend to run my suspension at 30% sag (my Yari’s don’t have any tokens in them). Works for me.
I truly don’t know how people can run 30 percent sag on forks with no tokens, especially the shorter travel forks which need more tokens. I’d constantly be running the risk of bottoming out and going OTB with a setup like that. 😕 😯
mindmap3Free Membertruly don’t know how people can run 30 percent sag on forks with no tokens, especially the shorter travel forks which need more tokens. I’d constantly be running the risk of bottoming out and going OTB with a setup like that.
They seem to ramp up big time and don’t bottom out constantly. With one token in and the Luftkappe they were just too harsh and I wasn’t getting enough travel out of them.
Or I’m just not as rad as you… 🙄
chiefgrooveguruFull MemberI truly don’t know how people can run 30 percent sag on forks with no tokens, especially the shorter travel forks which need more tokens. I’d constantly be running the risk of bottoming out and going OTB with a setup like that.
I think it depends on a lot of variables – the air spring curve, the damping curves, your weight and probably most importantly your riding style on the bike. And obviously how fast you’re riding and how big you’re sending it.
I’ll get pretty heavy on the front in the turns, especially flat ones, but as soon as I’m hitting rough stuff I’m loading the bike more through my feet. I don’t ride with 30% fork sag because I prefer the firmer feel with a bit less but I’ve tried it (pre-Luftkappe) and it wasn’t disastrous.
chiefgrooveguruFull MemberAnd Yaris are known to ramp up way more than Pikes or Lyriks due to the damper design effectively adding a parallel low volume spring to the main air spring.
mindmap3Free MemberAnd Yaris are known to ramp up way more than Pikes or Lyriks due to the damper design effectively adding a parallel low volume spring to the main air spring.
Yup. Tried them with one token and 20% sag and they were unbelievably harsh. On a normal ride I was struggling to use more than 100mm of travel. Without the token and a tad more sag they’re doing a grand job but I will be getting some coil forks in the new year because they’re just nicer.
The topic ‘Overbiked ? Underbiked ?’ is closed to new replies.
