gwurk
As with most of your *skills* advice Max
Care to enlighten rather than just post stupid memes?
Here’s the thing, if you’re riding say a 100mm fork, if you have it too firm you don’t use any of the travel, and too soft and you’re sitting on the bump stops, ime, this means you need to get the correct fork pressure and chamber volume within a pretty small range. But a 150mm fork, well, that extra 2″ doesn’t sound like much (phnarr phnarr) but againm ime, makes all the difference. Now, the difference in preload and volume makes much less difference, as the fork simply has further to move before it hits either end stop. And that also makes sag less critical, as “somewhere in the lower 3rd of the travel” is simply a bigger range!
Sure you’ll disagree but hey, that’s my experience from running bikes from 80mm to 210mm travel!
(btw, i’m not saying a poorely set up fork IS a good idea, but lets be honest here, most of the time we just want to get out and ride our bikes, not phaff around the in car park with a shock pump because we’re carrying a bit more water today or because it’s cold etc, so a bigger operating window is a good thing i think)
