@ reggiegasket – Thanks for the advice but Dead Sailor style is definitely not the way forward! As others have said it’s the reason most people get hardly any air when jumping and experienced riders get good height at low speeds. Not only that but I find if you don’t pump the transition and suck the bike up, the bike falls away from you in mid-air causing bad landings. You can get away with it on small single jumps, but will come a cropper on big jumps and sets.
So the consensus is too far back and late pumps are most likely the cause, right I’ll test that out.
Don’t get me wrong I don’t do it often, so catching it on video as suggested won’t be easy and TBH I’m not really a film the ride sort of person either!
@ Stevelol – Over rotating is an OTT description. Thanks for pointing out the mistake, my social media liaison has been severely reprimanded 😉
