The PFTE is good to ~200 from what i can remember and the rubber washer should be good to about 120 degrees, even if its the crappiest, cheapest nasty washer you can get.
Plus they are both connected to an extremely conductive pipe that will channel a lot of the heat into the surroundings (ground, house, water supply etc).
Biggest issue you’ll have is warm cold water.
Had that at a rented place years ago, the cold water supply ran through the wall behind the open fire. If the fire was running you either had to use the first cupful that came out of the tap, or run the tap for ages to get cold enough water to be pleasant to drink. If the fire was really going for it (most of the winter) you’d never get cold water.
So we put bottles in the fridge.
