Or have I completely messed that up? My basic maths is admittedly a bit rusty
My brain hurts after trying to work it out. Its a lot harder to type up in excel when you learnt it all on basic calculator.
Anyway for a 32t (129.8mm diameter) ring with 16t (64.9mm diameter) sprocket, presuming the 32t oval is equivalent of a 30/34 in its ‘ovalness’ (~16mm diameter diff 30-34) gives the following…
Top run chain length
30t 440.9161828
32t 441.1962665
34t 441.51348
So about 0.6mm chain growth over the oval. Of course this is calculated at the angle on a small sprocket so this growth would not be the same to a lower jockey wheel, it might be equivalent/less/more depending how much lower it is relative to the chainring (possibly a lot!?)
Growth would also be less in bigger sprockets and more in smaller sprockets.
