OTT Climbing: Quick...
[Closed] OTT Climbing: Quickdraw Question
Quite the opposite. they can increase the loading on the system due to their lack of dynamism
Grigri yes, SRC no. It's designed to slip a bit.
I know that none of the above solutions are perfect but they are better imo than something that is 100% useless if a tiny easy mistake is made. That is what I am getting at.
However people don't take kindly to you asking if they'll use your belay device instead of theirs. They assure you that you'll be fine then proceed to belay you badly 🙁
Posted : 13/06/2011 9:27 pm
get a bail 'biner or quick link to back off from a hanger
http://www.decathlon.co.uk/EN/quick-link-7mm-17410658/
or learn the magic sling technique to do it leaving nothing at all behind, if you are within 1/3 rope length of the ground.
stay safe, and have fun.
Oh and I suggest a helmet when outdoors. It's personal choice (before TJ comes to the thread) but 'draws get dropped, rocks get dislodged etc...and will hurt if you get struck.
Posted : 13/06/2011 9:52 pm
Understandable; I'd rather belay with kit that a) I'm familiar with and b) I know the history of.
Questioning your belayer's choice of gear implies that you don't trust them; if you don't trust them, don't climb with them.
Posted : 13/06/2011 10:20 pm
I don't trust anyone to be alert and correct 100% of the time, and that includes me. And then there are also factors outside of our control.
Posted : 13/06/2011 10:24 pm
We-ell, yes, that's sensible. But imposing your personal choice of equipment on someone isn't going to change that any.
Posted : 13/06/2011 10:27 pm
I never actually tried that beyond discussing it with a couple of close mates, because I knew what reception I'd get.
Posted : 13/06/2011 10:30 pm
TBH,
All things being equal, if your belay partner is incapacitated, you're pretty screwed regardless of kit. I'm not sure that the solution you're suggesting brings much to the table other than a false sense of security. If you gave, say, a Reverso to someone who'd never seen one before, you'd be unlikely to be any better off.
Posted : 13/06/2011 10:50 pm
I am somewhat surprised that there are not more reports of people being dropped for one reason or another. I'd google some if it wasn't so late.
Although if there was say a rockfall, and my partner was clobbered and I was knocked off, I'd rather be dangling helplessly than splatted on the floor.
Posted : 13/06/2011 11:00 pm
The most important part of the belaying system is the belayer, and all of the 'failsafe' methods are basically there for added convenience, not safety. The manufacturers still recommend belaying in the 'usual' way and whatnot.
If I came across a potential climbing partner who didn't have the confidence in their own ability to use a non auto-locking belay device (or someone to supervise them) then I just wouldn't waste my time climbing with them.
Posted : 13/06/2011 11:03 pm
What's that mean?
I am not advocating replacing the traditional techniques. I'm saying that given experienced belayers, a DEGREE of automatic safety (ie in some types of fall) in addition to that provided by an attentive belayer provides another level of security just in case.
I've done most of my belaying with an ATC, and I've stopped falls too, but the system is NOT fail-safe. This is not ideal, it's a simple as that.
Posted : 13/06/2011 11:12 pm
What we need, in an ideal world, is some sort of dead man's handle. I'm not sure that such a thing actually exists in a form that doesn't bring further risks or inconveniences.
Posted : 13/06/2011 11:24 pm
Yep. Inconvenience isn't an issue for me though, within reason. After all the rope itself is a pretty drastic inconvenience isn't it? 🙂
EDIT: thinking about it.. how about an electronically controlled pulley clipped to say your leg that goes around the slack rope; It's far enough away so you can belay as normal - the climber wears a little sensor that detects when he's fallen and sends a signal to the pulley to lock up, which pulls the rope and locks the belay device......?
Posted : 13/06/2011 11:29 pm
When you can find something that works with double ropes and pays out quickly while also being able to hold a fall then you might be onto a winner... working with frozen ropes would also be a winner too please... :o)
Until then it'll be bog standard belay devices I'm afraid.
Also, as pointed out above, while not being such an issue with sport climbing, in trad climbing the amount of 'slip' within the whole system means that the shock loading on the gear is a lot lower than when using any of the auto-locking devices.
Posted : 13/06/2011 11:36 pm
I'm liking the idea of a back-up device that mimics the belayer's hand only in the event of it not being available but stays out of the way otherwise. The advantage of an electronic system too would be that if your belayer was knocked out by a rockfall, say, you could remotely lower yourself down.
Posted : 13/06/2011 11:40 pm
And just how many sports crags actually suffer from rockfalls?
I'm not sure you're going to want to use anything like that when you are half-way up a bolted alpine route, or anywhere ever on a trad route where you might actually experience them...
Posted : 13/06/2011 11:57 pm
Trad climbers also use belay devices... and the system would be automatic, you would not have to do anything, and it'd be easily disable-able whenever you wanted.
Posted : 14/06/2011 9:50 am
I'd wager that alpine routes and electronic devices wouldn't be a great mix anyway.
Posted : 14/06/2011 10:04 am
No?
Posted : 14/06/2011 10:07 am
Back to quick draws:
Get a variety of legths from the shortest to half a metre. Keeping the rope straight cuts friction and means you'll still be able to move up when you've run out most of the rope. Especially important in Spain where the logic of bolt placement defies me.
Posted : 14/06/2011 10:32 am
No?
's hypothetical anyway, but whatever solution it was would have to work [i]reliably [/i]in extreme temperatures. Last thing you've want is a servo or something to freeze solid. I'm guessing of course, but I'd imagine that such a thing might be prohibitively expensive.
Posted : 14/06/2011 10:38 am
And to Molgrips:
Getting back down if your belayer dies, is knocked out, or finally gets sick of your insults and naffs off is no problem; you just tie off the rope on a bolt (or gear if you're unbolted) and ab' back down.
It's an interesting challenge, but there's no point working on it. It'd never sell, as most climbers seem to think that there's no issue...
Posted : 14/06/2011 10:44 am
50% failsafe
Que? 😯
Posted : 14/06/2011 10:55 am
Failsafe in 50% of situations I meant.
Posted : 14/06/2011 11:05 am
If you want a system where you have to be attentive to let the rope run freely, a bog standard belay plate with a prussik loop in your hand on the trailing edge works quite well and serves as a good, cheap and pretty effective failsafe. My climbing apprenticeship was long before Gri Gris and the like and this seemed to work well. Hardly ever used it for belaying tho', just for ab'ing. Never ever used a Gri Gri and - perhaps irrationally - don't like the look of them.
Posted : 14/06/2011 11:09 am
I like Grigris, makes paying out very very easy. And I suspect this is why they get used for newbies.
Prussic loop - fiddly. Maybe one of those petzl thingies that you can use for abbing.. but you need to keep one hand on.. perhaps a self-belay device attached on the climber side of your ATC would work nicely in the style of the prussic loop... hmm...
Posted : 14/06/2011 11:11 am
That's a little disingenuous. I don't believe that most climbers think there's "no" issue, so much as thinking that it's a fairly small issue in the grand scheme of things. We're back to acceptable risk again. Eg, it'd be safer but I wouldn't wear a full-face helmet and body armour for a cycle down the canal towpath.
I take your point, and anything that can improve safety without badly compromising everything else is of course a good idea. I'm just not convinced that it's a particularly common issue.
Posted : 14/06/2011 11:14 am
I mentioned this a while back as a suggestion. Not sure how well it'd work though because yes, it's fiddly, and faced with a free-running rope I wonder if the cord would melt before it grabbed?
Posted : 14/06/2011 11:16 am
For me it was all about travelling light. I preferred using a loop of 6mm/7mm cord as my failsafe for ab'ing than have to carry another device with me. Much more difficult to pay out, but then my reasoning is that the easier it pays out the harder it is to stop 😆
I don't climb much now, but I don't remember thinking stich plates (however you spell it) were a particular pain to use, but then I served my apprenticeship with my Dad who had vast amounts of knowledge, experience and skill when it came to climbing. [i]Some [/i]of it rubbed off on me
Posted : 14/06/2011 11:17 am
I for one don't and never will want anything more complicated than an ATC.
Even simple things like 'biners (some times not even screw gates) stop working properly in alpine and winter environments.
The best failsafe mechanism: don't fall off.
As far as abseiling goes, a prussic is very reliable, although I often don't bother with that unless there is noticeable rock/ice fall. Just getting the hell out of there fast is usually a big safety factor.
Posted : 14/06/2011 11:18 am
Pretty much as soon as you let go of the prussik with your main belaying hand, the system locks up. Maybe it doesn't work as well with the newer belay plates but with a stich plate it was very effective. Of course you need to make sure you put enough loops in the prussik and it does take a bit of skill, so not for newbies. Cheap, light and effective tho'
Posted : 14/06/2011 11:25 am
it really makes sod all difference what people use as long as:
-Its a recognised device
-The belayer knows how to use it [b]correctly[/b] and has [b]experience with it[/b]
-The climber is happy being belayed by that belayer on it.
Personally i always use a grigri for sport climbing or at the wall as i find it a bit more 'relaxing' to use for a full day of climbing, and its much better than a standard plate type device if the climber is working a route and having lots of rests.
For trad i'll use an ATC XP as i tend to climb on skinny doubles.
Theres always going to be climbers arguing the pro's and cons of each device, but as long as both partners are happy with the set up theres no point worrying / arguing about it.
Same goes for abbing, ive abbed on grigris and ATC's, as long as you have tried the device in a controlled situation and know how it feeds through on the ab theres no problem. I nearly always back up with a prussic though as it means you can take you hands off to sort out rope tangles, and it makes things feel less intimidating on free hanging abs (well to me it does)
Posted : 14/06/2011 11:43 am
 ianv
Typical STW, someone asks about one thing and everyone else goes off on a points scoring tangent about something else!
All thats missing is a few links to wikipedia and some photos of someone on a chossy trad route somewhere.
Posted : 14/06/2011 11:50 am
Yeah i expect the OP has probably long gone from this thread, probably out doing something much more constructive like riding or actually climbing :mrgreen:
Posted : 14/06/2011 11:55 am
Typical STW, someone asks about one thing, an interesting discussion develops, and then someone comes along and accuses everyone else of 'point scoring'. (-:
(Incidentally, "ianv" on a climbing thread? 😯
[i]*Does the "we're not worthy" scene from Wayne's World*[/i])
Posted : 14/06/2011 12:31 pm
Not a failsafe mechanism is it?
I didn't think we were points scoring? I think it's an issue, that's all. I've seen lots of bad belaying in my time.
Which is where we'd all rather be I imagine 🙂
Posted : 14/06/2011 12:43 pm
ok so I went for a climb and it was ace! massive rock face and lots of really nice bolted routes however I do have a couple of questions
1- at the top of the bolted route is a really thick wire or a double bolt with a chain and coming off these is what looks like a caribina but not bling just chain shaped but you can clip your rope into it like a bina.. I did check it out and it looks silky smooth - is this still advisable not to use and to go off another piece of equipment off this and leave it up there? - my mates were using that but they dont know loads
2- the way nature is means the rocks are all over the shop and I noticed on the way down there is usually a fair amount of pressure or rubbing with the ropes over pertruding rock... surely this is bad as it will eat away at the outer coating but I cant think of any other possible way that you'd get around this problem without a, leaving expensive gear or b, being risky... is this to be expected and it just means I will need new ropes quicker?
Posted : 21/06/2011 10:49 pm
I'd far rather a novice belay me on a grigri than simply explaining them how a traditional device works and hoping they do it right.
[url= http://www.ukclimbing.com/gear/news.php?id=3831 ]Errr..[/url] 😀
Posted : 22/06/2011 9:20 am
Alexx - the lower-offs at the top of sport climbs are there so that you don't have to leave gear behind when you lower off (hence the name). It's worth giving them a good visual inspection, but as long as they're not manky & rusty or have a big groove worn in them then they're fine to use. If you're going to be using those anchors for a top-rope it's best to use a couple of opposed quickdraws (gates facing opposite way so as to make it difficult to unclip) or a screwgate. This is more secure than the existing gear (normally) but also reduces the wear on that gear.
Posted : 22/06/2011 9:31 am
Can't help you with 1) as the wrong advice might kill you. Though I'd suggest you find out before you climb there again. It sounds like what you'd find at the top of a sport climb and if so is designed to take a rope. But seriously man, ask someone.
With 2) that's what slings are for. Theoretically, a worn sheath (ho ho) isn't a structural problem, as the rope's strength is in the core. That said, a damaged sheath might be a symptom of further damage. It also leaves the core exposed and can snag and catch. Personally, I'd either cut or bin a rope damaged in that way.
Posted : 22/06/2011 9:44 am
...or have a big groove worn in them
... which would cause things like [url= http://climbing.about.com/b/2010/10/17/worn-carabiner-cuts-climbing-rope-at-red-river-gorge.htm ]this[/url].
Posted : 22/06/2011 9:47 am
Re point 2) ropes are disposable items, and different conditions cause them to wear faster. I once binned a rope because it was in the same rucksack as a gas lantern where the glass had broken and left bits of glass everywhere. Not worth the risk.
Posted : 22/06/2011 9:48 am
Incidentally, here's one I photographed earlier.
Posted : 22/06/2011 9:54 am
If you have doubts about the gear that's there to lower off on, clip it and then try to pull it out before you lower off. Even in the highly unlikely event it fails the next runner down will stop you. If you then lower off gently you've got nothing to worry about.
As for rope wear. If you're using a double rope single then wear will soon make it unsafe. However, rope designed for single use will take enormous amounts of abuse, wear and low factor falls, and still survive a factor two fall.
Posted : 22/06/2011 10:02 am
I couldn't remember the term earlier but it's just come back to me. Are you talking about a Maillon?
Posted : 22/06/2011 12:42 pm
Page 2 / 3
