Hi, I wonder if the masses can offer me some advice on a T5 van. Yesterday I went to look at a T5, the advert mentioned a problem with the speedo and fuel gauge. After looking at it and doing some research I have found out that the ABS pump controller is not talking to the ECU. The Van drives perfectly, the mileage and price are spot on but I am concerned the ABS issue could be a bottomless pit of problems.
From the look (what I can gather from talking to the the seller) he bought the van with the hopes of changing the ABS pump and fixing the issue. I think he has done this, it has not solved the fault so he is selling it faulty. The ABS pump has writing on it as if it has come from a breakers, so it is not the original one from the van.
My question is, has anyone had any experience with changing a ABS pump and/or controller and coding it to the ECU? I have access to VAGCOM but from google searches it seems that this may not be enough.
Any help would be much appreciated.
Thanks, Mark,
