Evening all,
I have been using these forums for many years gaining information so I thought I’d post this info that’s taken me a few days to gather if someone is thinking of using a Monarch shock with their Orange Five. I couldn’t find a good answer in one place so this might be of use. For other bikes it’s a good idea to find the right tuning for the bike.
The answer is your recommended the 190x51mm sized Monarch with a M/M tune (recommended by SRAM email).
Ok a little detail if anyone was interested (please note all collected info not tested yet by myself):
The Monarch comes with different tunes M/L/H for the compression and the rebound (red for rebound and blue compression) marked on the shock. The new orange five comes stock with an OEM shock that is M/L with orange specific tuning. It was recommended that the M/M which is easier to find is a good alternative that they have had good feedback on being ran on the Orange five.
I spent a while trying to find out the difference between the high volume air can and the standard it got mentioned a few times it was based on the bike but I can’t find anything to back this up. People find the standard air can, can be a little hard for lighter riders and heavier riders prefer this option, but it is a better fit and forget option. The High volume can is more plush and allows you to adjust the chamber size with spacers which can be added. Rockshox tunning kit Part # 11.4115.039.000. If you find the shock is going through its early and mid travel quickly adding spacers solves this without affecting the small bump sensitivity. You can also use electrical tape wrapped around a few times if you don’t want to pay for the spacers to reduce volume.
The high volume sleeve can be removed (The Monarch manual covers this properly) after air has been taken out of the shock and you remove the o-ring keeping it in place. If you install some spacers before a ride this means you can adjust the amount of spacers on the fly while testing only needing a shock pump. You do need to remove the shock to take them off completely.
The difference between the RT3 and the RT is the number of adjustments. The RT has 10 clicks on both rebound and compression and the RT3 only has 3 on the compression. So more tuning scope for the RT but easier to adjust quickly with the RT3.
I’m sure I found out a few more things I’ll add if I can remember. Please feel free to correct any rubbish I have just posted.
Sugden
