As the title says, if you have or have ridden a 2010 Orange Blood, what is the best cable routing for the rear disk and a continuous outer rear mech?
There are a number of guide points on the top of the swing arm and the underside of the top tube, but if all are used there is precious little room for cable excess when the suspension is compressed. The main options seem to me to be:
1) Don't use all cable guide points, so more room for excess cable
2) Loosely fix using the cable guide points on the main frame so that as suspension compresses the cables slide back and forth
3) Re-route completely along chainstay over main pivot and along downtube where cable movement is minimal.
I would be grateful for any (knowledgeable) opinions or photos of successful routings.
Thanks
