andylc, I assume you’re coming into the woods from Taunton (north)? If so, you need the fireroad climb (quite steep) heading vaguely SE with the fishing lake behind you, all the trails I found head back down the hill onto towards the lake exiting back onto the fireroad. You can find the trails by spotting the exits onto the FR and pushing up, but IIRC last summer they were pretty overgrown at the bottom so I mostly either pushed straight back up the trail or cut up to the FR climb. As you’re climbing the fireroad you can see the trails in the woods to your right. It’s a pretty small area so easy to explore all of it. They aren’t really DH trails, more trails that head down hill… There was a bit of woodwork up there (I think that’s what google images shows). That’s come down now but there’s still enough jumps, berms and drops to keep it interesting. Nothing like on the scale of Triscombe though, but I can ride to OP in 20 minutes so it’s great for an after work blast. The trails used to be fairly extensive and run all the way down to the lake but a lot of trees came down in the last year or so, I’ve not been there since the autumn so not sure how much (if any) has been cleared recently.
