http://www.thesun.co.uk/sol/homepage/news/2737230/Into-each-life-a-little-crane-will-fall.html
Something badly wrong there. There's all sorts of alarms and systems in those cranes to stop that happening. I'd say the driver is squarely to blame.
Blimey!
That's a rare example of a really pleasing punning headline.
That a bad accident. Your right in that these things do have massive amounts of monitors showing wind speed, SLI's etc, but there are often factors that the driver cannot anticipate. I;ve seen a crane accident where the ground gave way under one of the outriggers.
Whoever did the birthing plan will be shitting himself no doubt.
Good job they cut down that tree it could have blown onto the house in a storm.
Why were they using a crane to lift the tree over the house? Why didn't they just bacon slice it? They can't have been wanting to use it for timber as it's got a massive bend in it.
Agree about the alarms.
I use to be low paid builder when I was student. However the building site manager did spot I was more brain than brawn, so I use to manage the crane and to to help with the tracing.
The crane would start buzzing and stop pulling up the hook if the weight was above 1500kg.
I'll send that to a riding buddy who actually build crane for a living to see what he things of it
Totally the crane companys fault
A lift this size is alway a contract lift. They should ensure every precaution is in place before they start the lift an monitor everything during the lift.
First thing I can see is that the crane was in the wrong position making the out riggers ineffective.
I take it the second crane is rescuing the first one.
Because they're yanks............and using a sledgehammer to crack a nut is always the best solution.
Since the supported distance from the base of the jib to the horizontal axis of the rear outriggers rear axle is longer than the distance from the base of the jib to the outside of the outrigger, for distance support purposes they had the crane orientated the right way round. They just didnt calculate the moment around the line of the rear outriggers rear wheel as a pivot correctly.
All I can say, is that if they try to right that crane now, it's going to come up with a big wallop and flick the 'rescue crane' bak over into the blue house. I'll keep an eye out in the paper......
They just didnt calculate the moment around the rear wheel as a pivot correctly.
Is that what happened here too ?
couple of big blokes sat on the front bumper of the crane and they'd have been fine...
I like that they appear to have a second crane there.
Presumably to pull the first crane out
Anyone got the sequence of cranes falling into the harbour in Ireland - that always makes me lol too.
ah well, winner for the owners - the main house is fine, and they'll get a hefty payout from the crane company('s insurance).
and presumably the tree will get removed with the crane!
Just read Construction News cranes are always falling over.
Apparantly the crane was 'shockloaded' when the tree snapped when being lifted.
Still shouldn't cause that as those types of cranes even at 80% of thier stated lift capacity are still well within their ability to lift safely.
Somebody got their sums wrong
you've just f*Cked my head up
They extended the long pointy bit too far
anyway I like this one
Can't see any counterweight on the crane.
looks like a 150 with a little fly on it.
kuco that video is pure class, £10k car wrecks £250k worth of crane.
it,s been doctored the second wagon never went in , also if you have the room where your siting the crane you always try to lift over the back of the crane, but it will lift to it's max 360 degrees and in this country the crane has to lift upto 125% while being tested for it's 4yr test .
Indeed, which is why I posted the snopes.com link that says exactly that.
Still funny tho
If you want to see a truely scary crane crash watch this and turn up the volume.
The sound of the main slew pin snapping does not bode well!
i watched that big blue one earlier, nasty.
Or you can just look at the photos and see it's poorly photoshoped.
Weird... I googled 'crane buzz' and this thread came up, so I thought Id ask you guys;
I live in the centre of Malaga and have one of those remote controlled cranes near.
At exactly 7AM it starts buzzing REALLY F*#KING LOUDLY
Why is it doing that and should it be doing that?
Are you talking about the alarm to warn you that it's moving? If so, I guess it's because it's moving and the guys are working.
PeterPoddy - Member
I wouldn't bother, its not recent. that picture has been doing the rounds for years.
