Need a new one, both mine are pretty old and had too many crashes, is there one i can get that will do for both?
Bike Forum
One helmet for Road and MTB
Posted 2 years ago #
i use a Specialized 2D for both road and mtb, it does for both, but then again, why wouldn't it?
Posted 2 years ago # -
I use a Met Inferno UL for both.
giro hex is well ventilated & not that faraway from same shell shape as a road hat, despite the rad-lite claims they make
giro monza for me, for both.
Giro E2, lose the peak for roadie duties though otherwise prepare for a very sore neck.
Uvex X-Ride? Looks the part and I have one on order at my LBS.
I use a Giro Ionos for both.
Dunno if you can still get them but I use a Met 5th Element for both.
S-Works 2D is far and away the most comfortable helmet I've ever tried, and I've tried a lot! Very light, fits most people too IMO. Not cheap mind.
Catlike Whisper Plus.
Just use a roadie helmet. Looking at mid level Giro (£60) The only difference between the roadie and mtb helemts is the name and peak.
Giro Monza.
[EDIT: I don't own a road bike but this is the helmet I wear most often because it's comfortable and it appeals to my vanity, though not as much as an Ionos would...]
Have had both Bell Sweep and Giro Athlon and used both for road duties removing the peak.
Athlon is good, the Sweep was great.
would I be right in thinking you use the same head for both types of riding ?
Topic Closed
