On-One Slot Dropout...
[Closed] On-One Slot Dropout - Alfine
[#2009272]
Hi
Looking to buy a On-One Inbred 26er Slot Dropout Frame 2nd Gen, and fit my Alfine hub.
Is there anything I should know? How do you maintain chain tension. Are there any clearance issues. Will it work?
Cheers WipeOut
Posted : 20/09/2010 6:51 pm
Should work fine, when i fit my alfine to a Cotic Simple i just tension the chain by hand and do up the nuts with a spanner, no need for any kind of chain tug etc
Posted : 20/09/2010 7:14 pm
works fine in my 29er slot. no need for chain tugs so far,
Posted : 20/09/2010 7:39 pm
Looks promising.
Posted : 20/09/2010 8:38 pm
Yep works fine on my On-One slot Inbred. http://www.muddymoles.org.uk/2008/12/alfine_review.html
Posted : 20/09/2010 9:10 pm
Hmmmm. How wide are alfines?
Posted : 20/09/2010 9:15 pm
135mm like std MTB stuff
Posted : 20/09/2010 9:16 pm
 mboy
I use a single On One chain tensioner on the drive side of mine, with one of the non turn washers on the non drive side. You only need one washer to make sure the hub doesn't spin in the frame, and using a single chain tensioner helps me to set my chain tension correctly.
Posted : 20/09/2010 9:18 pm
