Viewing 14 posts - 1 through 14 (of 14 total)
  • On-One Carbon 456 – how flexy is carbon fibre??
  • jb79
    Just took delivery of one of these today- is it normal to be able to deform a carbon fibre tube by pressing on it with your thumb??
    Bit disconcerting….
    fadda
    You’ll be sending that back, I’m afraid. Unless you have bionic thumbs…?
    saladdodger
    Yes its okay
    But be careful in the winter because carbon fibre goes brittle in cold weather
    br
    I could do the same with my carbon XTC, just don’t do it.
    votchy
    common test carried out on carbon fishing poles, some of which cost in excess of £4k, section strength tested by squeezing, as for carbon being brittle in the cold, never seen any issues with carbon fishing rods being bent double in sub zero temps
    Marmoset
    I can do that pretty easily on some sections of my Vertex RSL.
    andyl
    fadda – Member
    What a load of crap.
    It is perfectly normal. The frame is so thin in places that yes you can deform it easily with your hand but don’t worry.
    HansRey
    compressive strengths of CFRPs are pretty poor, and if in the transverse direction too, i’m not surprised. I’m not sure if it’s worthwhile sending back as I’ve never had a c.f. bike 🙂 If you couldn’t compress it then I’d guess it’d be very thick and overengineered.
    PeterPoddy
    It’s not. They’re all like that (C456s that is) Well, mine and the other 2 I’ve seen are like that anyway.
    FWIW the C456 is a fairly overbuilt frame these days. Chunky and strong. 🙂
    fadda
    Maybe I have weak thumbs, then… 🙁
    HoratioHufnagel
    you can do this on most lightweight aluminium frames too! Certainly could on my old Klein.
    bigdugsbaws
    The TT on my road bike compresses significantly in the hand too, worries me that it will slip out of the clamp when being transported by car.
    jb79
    Cheers folks, reassuring. Always had steel or alloy frames before.
    andyl
    It’s not really anything to do with poor compressive strength of CFRP.
    It is actually far simpler than that and to do with the geometry of the top tube which has quite small radius top corners with a wide curved top piece and the fibre orientations along the top tube will be predominantly along it’s length for stiffness in the main load direction and in +/- 45 deg for torsional rigidity and robustness. 90 deg fibres will most likely be there but they are not as important for the overall load case and i would rather the frame is designed to flex like that than be overly rigid and fail at a corner.
The topic ‘On-One Carbon 456 – how flexy is carbon fibre??’ is closed to new replies.
