I know this has been somewhat done to death, but here’s my current problem:
Old two part #3 Hope M4, 2010ish 20mm Rev with PM, A-Z caliper adapter (the one with zero upsize)
Adapter fits fork – just – caliper won’t quite mount, it fouls on the head of the top bolt at the adapter against the section of the caliper body where the body half bolt is running through.
I’m not sure removing any material from the caliper body is a good plan, a lower profile bolt head into the fork might do it but I can’t find one – currently using the standard Ti taper head bolt that ships with the adaptor.
Don’t really want to change brakes or fork, do have a set of 200/180 rotors I could use if I went +20 which I think would solve the issue, but I really don’t need 200/180.
What would STW do?
