Im on oil and have been at 3 different houses now
I prefer it for the visual effect it gives the mrs when she has been using the heating alot , basically its an if you use it alot during this bad weather instead of using the wood burner then youll have none left if the oil truck cant get in to deliver…..
As for cost – the house i had gas in cost a bucket load to heat due to being badly constructed and poorly insulated.
The las 2 houses have been insulated to the highest standard and im doing the same with my current house a the moment.
My neighbour spends 2 x 700 quid fills a year but never uses the wood burner and doesnt have even a 1/4 of the insulation i have – so far year to date ive used about 300 quid. – and thats with a 70% efficient boiler that was heating a tank of water. Next weekend a 91% efficient condensing combi is going in.
