I'm running a tubeless setup with a 2.1" high roller at the back, and I'm just not getting on with it.
The back end feels like it has no grip at highish pressures (>30 psi), and and it feels like I'm going to bugger the rim at lower pressures as I can feel things "clunking" the rim when I hit obstacles. When I run at the lower pressure, it leaves usage marks on the rubber between the knobbles (if that makes sense)
I'm getting on ok with the same width tyre at the front, and am happily running that at 30psi and not feeling like I want more grip.
Do I:
- "need" to try a wider version of the high roller
- "need" to swap to another tyre set up (Got on great with nobby nics apart from buggering the side walls, but that was with getting snakebites and tubes)
- learn to love the "clunk" and get on with the lower pressure?
