Viewing 10 posts - 1 through 10 (of 10 total)
  • Offset head set cups – can I use them to increase reach?
  • ddmonkey
    If I run them both the same way will it work and make my effective headtube a bit longer?
    raisinhat
    Yes, but only by a few mm. You’d be much better off getting wider bars or a longer stem.
    crankrider
    The bearings are not flat they are at an angle so it would not work – not a good idea.
    Peat etc had some for this years dh races… just offset no angle change.
    ddmonkey
    Yeah wide bars check, slightly longer stem check (but don’t want to go longer than 50mm) and every little helps when it comes to the headset 🙂
    ddmonkey
    So if Peaty had some was that pro-only or could I get some?
    Northwind
    None that I’m aware of on the market but it’d be an easy enough think to make.
    ddmonkey
    Cheers all. Maybe if I ask cane creek nicely…
    davidtaylforth
    Get a 60mm stem, honestly!
    ddmonkey
    Long stems and wide bars = crap handling.
    davidtaylforth
    To be honest, I’ve tried various stem sizes over the years (maybe my bars arent wide enough though) and I found 70mm was the point where things went a bit ****, 60mm always felt good to me.
The topic ‘Offset head set cups – can I use them to increase reach?’ is closed to new replies.
