Ok, I’d suggest you start in peaslake as the trails a easier to find and there are usually more friendly cyclists around. Sat nav just google the hurtwood inn and there’s two car parks there, one just up the hill if you drive 300 yards past the hotel. From pedal and spoke bike shop oppo the hotel there is a path that goes up past the church. Follow that up the hill and it will take you to the top of pitch hill. There’s a couple of tracks on the right hand side as you go up. It feels like you’re at the top, there’s a cross roads in the fire road where straight on enters a wide but more obviously wooded area. Turn right there and you’ll see an obvious entry about 50m on the right. There is another right turn about another 50m further on where you go up a 1m steep up off the fire road. There are more trails around on pitch, relatively easy to find. For steep stuff stay on the original fire road until you get to the very top, as far as it goes. There’s a number of trails that go straight down in front of you, east to spot. From there head over to winterfold area, ask for Evian or two headed dog.
Back at the bottom by the shop if you go up the hill on the left so to speak, then that takes you onto holmbury with Barry knows best, yoghurt pots etc. Personally prefer pitch and winterfold.
Hopefully that’s some use and vaguely clear! Have a great ride, should be relatively dry up there.
