O rings for Avid bl...
[Closed] O rings for Avid bleed kit/ caliper port.
[#3416473]
I could do with some replacement O rings, the tiny ones on the bleed kit fitting. I have no idea of the spec/ dimensions, possibly 6.5mm external diam, 4.0mm internal and a thickness of 0.7mm. Any ideas where to source the correct ones?
Also- the tubing is now pretty opaque and very stiff. Again- ideas for replacement?
Or just buy an Ebay bleed kit and be done?
Posted : 01/12/2011 4:45 pm
just used an ebay kit for the first time with no ill effects.
Posted : 01/12/2011 4:50 pm
It seems a bit wastefull to buy a new kit when all I need is a little bit of pipe and some rings 🙁
Posted : 01/12/2011 4:58 pm
