No need to enable anything.
What sort of drive is it? I assume it’s an external. If it’s a desktop 3.5″ drive, is it powered up? If it’s USB powered, like a 2’5″ SATA/SSD, then it might be the cable?
Bottom line is, Macs will read NTFS.
This is the current preferred file system of Windows (beginning predominance circa Windows NT 4.0 and Windows 2000, and including Windows XP). Most Windows systems use principle partitions with this file system. This is a journalled file system with good support for large files. It should be noted that it does NOT support POSIX permissions or ownership. Mac OS X has read only support for this format. It has no capabilities to write to an NTFS drive. Windows has complete read/write capabilities for this format.
http://guides.macrumors.com/File_systems#NTFS
