Nobby Nic No More.....
[Closed] Nobby Nic No More.....Maxxis Ardent's or something else ?
[#701716]
anyone using Ardent's yet ?
thoughts / opinions ?
fwiw, the NN's are finished, sidewalls too thin, they were almost semi-slick however.
prepared to put up with extra weight for increased sidewall strength / puncture resistance......
or any other thoughts.
large volume (2.25" to 2.4" max) is my requirement.
tia.
Posted : 12/07/2009 6:20 pm
Rubber queen?
Posted : 12/07/2009 6:21 pm
cheers - anymore suggestions?
big betty?
fat albert?
Posted : 12/07/2009 6:22 pm
big betty's on my FS. they're too much tyre for the HT 😀
Posted : 12/07/2009 6:25 pm
2.4 ardent 62a one of the best tyres i have used, really good in everything tbh
Posted : 12/07/2009 6:44 pm
Just mounted up some 2.25 Ardents tubeless on my Flows. Very similar to my UST 2.25 RR's in volume and weight, thought the sidewalls feel thinner on the Ardents.
Posted : 12/07/2009 6:53 pm
anyone run LUST high roller 2.35"s on 819's ? snaps - your opinion gratefully requested.
Posted : 13/07/2009 10:05 am
have you tried the alpinecross or snakeskin NN's?
Posted : 13/07/2009 10:07 am
tlr, i have used 2.35 on 819's and found them to be OK, they would roll of the rim a bit if using really low pressures, but most wide tyres are the same on 819's.
Posted : 13/07/2009 10:08 am
richc - i need UST for my 819's preferably.
realise now that Ardent aren't UST available.
Posted : 13/07/2009 10:09 am
si - cheers.
i'm not into really low pressures. 35psi for me usually.
any lower and i have too may problems.
Posted : 13/07/2009 10:10 am
I've ran them using stans kits and sealant no problem. SO they could be worth a look
Posted : 13/07/2009 10:16 am
richc - sorry - run ardents or HR's ?
Posted : 13/07/2009 10:23 am
Lecht - i'm running high roller (non UST with stans) after i got them inflated (rim setup nothing to do with tyres, to be fail for a none ust tyre they have very few leaks, nost were from sidewall damage i had done). if i run them lower than 30 psi they feel to floaty and i worry about rim damage (i'm not graised with fineese with my riding i just plough though) grip well and don't roll (or the rim) in corners, still trying with the setup atm though.
Posted : 13/07/2009 10:37 am
fozzy - i have on/off success with UST.
quite happy to pay for the LUST version, and add latex.
i simply want fit and forget reliability, not bothered too much about additional weight........
Posted : 13/07/2009 10:40 am
i run 60s kev front and rear..
after a few tests this weekend, (bad back currently) found 30psi (front) and rear 35psi to be the best for me, i've taco'd a set of wheels (317's) and don't like running to low as they felt spongy..
someone will ask why run tubeless then, will i rarely puncture my tires but i pinch tubes a lot..
Posted : 13/07/2009 12:24 pm
Yes, on the front of my Reign.
My easiest tubeless fitting experience yet, all went perfectly and has held for months now. Used Joe's liquid.
Great all-round tyre, very grippy for a normal compound.
Posted : 13/07/2009 1:22 pm
I used the LUST 2.35 highrollers for a while, they did not last very long and I'm no mile muncher. I'd rate them "ok" rather than "good".
Posted : 13/07/2009 1:25 pm
ok - i'll give them a bash - thanks folks 😀
Posted : 13/07/2009 2:04 pm
Ran a HR LUST 2.35 on the front and it seemed pretty good but they weigh a ton (well a kilo anyway) so swapped to a Blue Groove for the moment on the front. Advantage 2.25 working OK on the rear (non UST model but using it tubeless).
Posted : 13/07/2009 2:18 pm
fuzzy - @ 1kg, they're likely to have a pretty sturdy and strong carcass then 😀
Posted : 13/07/2009 3:37 pm
