night ride in the f...
[Closed] night ride in the fog??
[#214687]
going for a night ride tomorrow and its really foggy round here tonight looks like it might be the same tomorrow so anyone got any tips??
Posted : 14/01/2009 6:28 pm
Don't go if you don't have to. I've driven over the Pennines from where I live to manchester in the fog and too often see cyclists up there too late. It's a wonder that they survive. It's an unneccesary risk to take.
Posted : 14/01/2009 6:29 pm
fog, at night, in the woods, solo - totally brilliant!
Posted : 14/01/2009 6:32 pm
 Keva
I rode early this morning in the dark & fog. I was surprised by how much I couldn't see, lights didn't help much either, just made the fog brighter!
Posted : 14/01/2009 6:33 pm
I'm with 5spot - sounds like a hoot, un-necessary risks are what make the world go round, or at least what make it exciting! 🙂
Tips -
Take a route you know. Or a GPS and a map.
Take spare clothing in case you get stuck.
Take some nibbles to see you through if you get stuck.
Take a mobile.
Posted : 14/01/2009 6:35 pm
from last couple of night rides in the fog, a big tip is bar mounted lights not helmet. mine ar helmet mounted and i was blinded at any sort of speed, whilst my mate has bar mounted and had much better viz. i suspect this is due to helmet mounted light being reflected straight back off the water molecules into your eyes as they are at the same level.
Posted : 14/01/2009 6:36 pm
good advice!
Posted : 14/01/2009 6:38 pm
Wonder if the bar-light would be better moved to the bottom of the fork stanchions. Interesting thoughts.
Posted : 14/01/2009 6:39 pm
night vision googles!
Posted : 14/01/2009 6:40 pm
that describes mountain biking itself :o) Fog is fun, in an I-can't-see-where-I'm-going-properly way - just a different sort of challenge!
Posted : 14/01/2009 6:41 pm
I often ride in fog - but never on always off road
Switch off your head light and run your bar light at a lower setting if you can
The glare is just impossible to see with otherwise
Ive even switched them all off when its been that bad
Posted : 14/01/2009 7:41 pm
 pcb
I don't see the big deal is to be honest.
Take the usual precautions let someone know where you are going etc.
I only run the light on the bars, way to much dazzle from the lid light.
Posted : 14/01/2009 7:51 pm
what iamsporticus says, if you've got a helmet light on it's like riding into a white wall.
Posted : 14/01/2009 7:57 pm
When I was rally mechaniching we used to cover the lower half of the spotlights, try this on the front of your bar mounted light. This cuts off the upper setion of the beam reducing the light reflected back at eye level - similar effect to a car fog light.
Posted : 14/01/2009 8:31 pm
Night riding in fog is ace.
Gives the 'things' somewhere to hide as well!
Posted : 14/01/2009 8:34 pm
