Just pressed the button on some shiney new prime 50mm carbon clinchers, which leaves me with the question of what tyres to fit?
The obvious choice is a set of GP 4000s which I currently have on the existing wheelset. But the new ones are tubeless compatable, so I’m tempted to go for the Pro Ones
Cost around the same once you factor in buying tubes, and weight isn’t much different all in
I’m keen to try the tubeless option, but then again they look to have a fairly short shelf life and these wont be used for racing only.
Swaying towards the gps with tubes as I’ve never had an issue with them, but feel free to tell me I’m making a big mistake.
If I do go wit the latter, do I need 25mm. Currently run 23mm, but these appear out of fashion
