Hi, I’m new to this rear suspension business, I have a couple of questions. I have a specialized pitch.
My shock pivot bolt appears slightly slack in the bush. Lifting up my seat, i get the tell tale sign of a loose bush, but it has been recently replaced along with the spacers. Removed the shock from the bike, there is no play between the bush and shock or spacers and bush, I did notice quite a bit of slack between the pivot bolt and spacers. IMO, this is what is causing the slight bit of play in the rear.
Is this normal or acceptable? A off the shelf bolts diameter is not going to be made to a tolerance that allows a nice snug, slip fit. Is the bolt that comes stock on the frame more than a off the shelf bolt, a custom bolt? Is it normal for it to wear during use and need replacing?
During turns which you’re really nailing and pumping hard, is it reasonable for the suspension to compress around 75%? In my head a lot of force is going down from your body, through the bike, to the ground, then a reaction force from the ground to the bike, it’s reasonable right?
