My pick up’s (ISUZU Hi Lander) rear tires edges are ‘raggedy’. There’s still a lot of tread and the tread depth/wear is even on all 4 tires so I don’t think it’s a worn component or tracking/camber issue.
It’s the edge of the tire that, when the tire is touching the ground, is at the rear. The front edge of the tread pattern if you’re looking down on the tire.
The tires seem to be in a generally good state. No bulges cracks etc. The material doesn’t seem crumbly or otherwise problematic.
The tires are BFGoodrich All Terrain T/A KO, 265/170R16 112T.
I don’t want to replace them needlessly; they’re a long way from not having enough tread and it’d cost 500GBP. I also don’t want to crash!
Should I (a local garage, considering the weight of the buggers) rotate the tires? Should I replace them? Honestly, I wouldn’t trust a mechanic’s opinion here in Thailand. Esp. one who stands to sell me something!
I’ve tried to take some pictures, but they came out terribly.
Thanks a lot
