Everyone – forge is a bit late for April Fool’s Day! It’s a kiddies trail with a shonky bridge – don’t waste your time on it cos the other side of the forest is better for fun 👿
Well done to the BOB/Gorrick people for their hard work. Polite request: could that nasty ditch be made safe for me please?
Proper job! Lovely new section of trail that rides well in both directions and links in well with the existing stuff. Big thanks to all involved with the work, it’s much appreciated. 😀
cg – just because I found it before you 😈 Take it you went out to investigate this afternoon then ? There is a down and up very mini bomb-hole that is quite tight.
forge – yeah, couldn’t help myself! Rode it in both directions 5 times but couldn’t do the bridge both ways cos of the tight turn. That makes the correct direction starting from almost opposite the tank trap 😉
Nearly had a nasty in the ditch and as for those hairpins …
cg – bridge works both ways for sure but not so good in reverse, I didn’t the first time but second time I did it was fine. Berms on that trail are great 🙂
i rode the full length of the new bit that leads to the tanks traps for the first time last week, now i see i was a few yards from even newer stuff…will have to check this out friday
Another thumbs up from me to. Nice to have a really tight technical trail quite different from a lot of the other yellow brick roads at Swinley. Cheers BOB and Gorrick.
practice makes perfect, good to have some challenging stuff in there… Think I might have to try and get out earlier this week then. My friend had a little ‘off’ through the bombhole you mentioned too, hoping by the volume of traffic that it will soon wear in though.
